20 Most Recent Tissot T33.1.588.51 T-Touch Dial Questions & Answers
Battery replacement is it a dealer only job?
This is a Myth my friend.Anyone can change a battery on Tissot T Touch.The First models have 2 steps the Battery Replacement and Synchronization.After the Tissot Expert add the Reset as third step. In my blog i have instructions with video how can you do that. www.watch4maker.com
11/1/2014 4:59:34 PM • Tissot... • Answered on Nov 01, 2014
Tissot T33.1.588.51 T-Touch Black Dial?
If the functions dont work from moisture I can repair it. if the sensor damaged the watch is unrepairable and only the swatch group service center can repair this watch.please check my Blog i have many posts about these problems for all Tissot T Touch Series Watchmaker Video Review For Watchmakers and Watch Fans
11/1/2014 7:42:33 AM • Tissot... • Answered on Nov 01, 2014
T33 insert sim problum
gild t33 insirt sim problam kya kare
1/21/2011 5:10:53 AM • Tissot... • Answered on Jan 21, 2011
The dial of my new
I would rush it back to the jewelers, because any intervention from you or anybody else will void your warranty.
1/14/2011 8:43:56 PM • Tissot... • Answered on Jan 14, 2011
2answers
Tissot T-Touch
Hello, if u read the user's manual, there is an option to resync the hands. Goto the units mode ( Press the middle button, and then twice in the center of the screen, so that the digital display shows either 24h Cm or 12h... u get it ) Once in that press and hold the middle button for 5 seconds, until the display shows SYNCHRO. Then use te top button to adjust the minute hand and te bottom button to adjust the hour hand, and bring them both, one on top of the other, over the 12 o'clock position. Once this is set, press the middle button again. This should to the trick.
7/16/2009 4:30:34 AM • Tissot... • Answered on Jul 16, 2009
Can't set date. Did set time
Paste this link into your browser and use interactive tabs to sort out everything:
http://www.t-touch.com/flash.html?20090307051010
Do not forget to rate, please.
3/7/2009 5:21:41 PM • Tissot... • Answered on Mar 07, 2009
2answers
Tissot issue
I have a similar problem which started this morning. My watch is almost 5 years old, and is on it's original battery. I suspect this is the first sign of the battery dying.
12/6/2008 7:03:38 AM • Tissot... • Answered on Dec 06, 2008
Wot size battery do I need for a t472 tissot trace
I think that's a SR936Sw or equivalent. That watch has a pop-off back, so its easy enough to access. You'll need a jewelers pincers or something like a sharp pin to extract the battery (Carefully!) as its embedded in the body.
4/9/2016 1:10:11 PM • Tissot T Watches • Answered on Apr 09, 2016
What is the reason my new Tissot watch is not working, which was bought in switzerland this year January?
If your watch is battery operated, the most common reason is battery itself. Don't mind it was bought in January, because watch itself could be in shop storage for years (even if it is one of the new models). If your watch is automatic/hand wound, then there might be a problem with movement and in this case you will need help of qualified watchmaker.
8/26/2014 3:42:06 PM • Tissot T Watches • Answered on Aug 26, 2014
Why Touch does not work after battery replacement?
Was the battery empty in the first place, or was the watch already defect? Did you put in the correct and a new battery? or perhaps you did put n the old battery? can you measure the voltage of the batteries, to check? Just a few questions that came up with me.
7/23/2014 11:58:46 AM • Tissot T Watches • Answered on Jul 23, 2014
Just got the battery replaced on my Tissot Supersport Chrono and now the chronograph buttons do not work. Any suggestions before I take it to a authorized repair shop?
Take it back to the shop that changed the battery. They have slightly misaligned the movement to the case. With a watch as good as a Tissot it is better to use a Tissot authorised dealer. My Seiko goes from Canada to London, UK for service.
10/26/2022 10:42:31 PM • Tissot Watches • Answered on Oct 26, 2022
How to set moon phase on tissot pr100
for Tissot PR100 Automatic Chronograph with moonphase, minute recorder, hour recorder and seconds subdials, to set the moonphase there is a sunken button between the chronograph start/stop and the winding crown. Using a pointed object such as a ballpoint pen, push the sunken pusher gently until the moonphase moves one step, (if you press the pusher completely in, it will also advance the calendar hand, so only press enough to move the moonphase and no more for moonphase adjustment)
9/18/2021 6:20:20 AM • Tissot Watches • Answered on Sep 18, 2021
2answers
Hi, I have tissot expert, when I changed the battery, all option work perfect but the screen to activate compass not working and the bip as well,maybe battery not suit the watch ?
It could be that you have purchased the wrong battery for your watch and you should take it to a person that repairs watches and jewelry then to figure out what type of battery that will work in your watch.
3/8/2021 11:53:37 PM • Tissot Watches • Answered on Mar 08, 2021
How to zero the dials on Tissot 1853 watch
The reset button may be defective
11/16/2020 8:15:42 PM • Tissot Watches • Answered on Nov 16, 2020
Tissot T33.1.588.51 T-Touch Dial Logo
13 questions posted
Top Tissot Watches Experts
Ngoro
john h
k24674
Are you a Tissot Watch Expert? Answer questions, earn points and help others
View Most Popular
T Tissot
  • T Tissot
Most Popular Question
battery replacement dealer only job
  • Watches
